Activity Feed Forums Flooring Reviews Undercut grout debate (I’m in a pickle) Reply To: Undercut grout debate (I’m in a pickle)
  • rodc
    September 13, 2024 at 1:42 pm
    Thanks Joe, I wasn’t sure if we were on the same page about using the glue as a spacer. obviously it’s really not possible to secure it with any sort of straight edge spacer. Thanks for your input.
    I did run into a small issue scribing the last 2′ of plank it’s throwing me off 1/8″ inch on the straight edge. I will have to go back and cut off a bit more. Other than that, it should be great. I wanted to spend some time before this weekend to do that so the rest goes fast.
    As far as the dishwasher, Yeah, I was dreading emptying out the cab. under the sink to get to the hoses. Not that it is a mess just that there’s still a lot of stuff under there. I was just worrying about the dishwasher being level in order to drain properly..
    Thanks for the compliment on the scribe. I would say it would have taken about 2 hours from my day this weekend to finish that big room. Actually the scribing is time consuming but the cuts are easy. I’ll probably use the die grinder with a flap disk to cope that last little bit to deal with that 1/8″. The scribe is right at the top but the way the grout comes to the floor is at an angle so it pushes the plank away.
    It’s just the last piece about 2′.
    Thanks again for you help and if you have any ideas to deal with the grout to floor would be appreciated.
    RC
