Activity Feed Forums Bootcamp Corner – Weekly Calls Corner fireplace Reply To: Corner fireplace
  • Cathy
    June 7, 2024 at 1:15 pm
    Thanks so much for your video. You gave us a lot of info and helpful suggestions.
    So, yes, the tile area is higher at center right than the 2 sides. That is where the crazy hard rocky concrete is that barely changes with hours of grinding. Any tips that might give us better results?
    And as you described in your video, there is a high spot in front of that one, about 6-8 inches in front tile edge. Since there is some, maybe not much, self leveler over that area, that should grind off before we hit that stubborn stuff and might mean less grinding (fingers crossed).
    The T molding def sounds like the best way to cover tile edge. I don’t think it will look bad, will make it look finished. Possibly even accentuate that tile.
