  • Jeff
    May 28, 2024 at 3:38 pm
    Joe thank you for your reply ! First off you are correct the floor drain is beveled. I really would like the flooring all to match and like your idea of raising the drain and using a concrete leveler there. Because there’s a sink and a washing machine in there I know I risk some water issues if there’s a leak, but I’m willing to risk it with a flat drain.
    In regards to the den area, you’ve given me something to think about. I will likely go ahead and buy the flooring to do it and not risk them discontinuing it. Moving forward let’s just plan on that room getting done even though it will likely be completed last. Is that possible or will I need to start in there ?
