Activity Feed › Forums › Where should I start – Post drawings and questions › Freeberg project › Reply To: Freeberg project
You started out the last video with exactly what I’m looking for. I want to be able to go into the bedroom doors just like you mentioned. Not only for looking better and hopefully easier. Also, because I’m doing this in stages I can work on each bedroom as I can. So I don’t have to rip up all the carpet until I’m ready to go. Thanks for taking the time and showing where to snap lines. Pointing out the critical areas to keep straight. I will show you a picture of what I’m trying to avoid from previous flooring. I’m actually going to practice and visualize before ripping everything up. I have sample pieces and just take some measurements to have a idea. When I do the 10 planks if the measurement is closer to 8ths is it safe to go with that or does it really matter if its closer to 16ths. Just curious. Thanks again. And the pic is a transition into a closet. It’s in the hallway from front door to kitchen.
