  • Dan
    August 20, 2023 at 11:24 pm
    Thanks for the follow up Joe!
    Regarding the bathroom, I think it’s cement board. I attached a close up of it. I was able to score it with a utility knife, so I’m guessing that’s what it is.
    I’ve also attached a close up of the border between the vinyl floor in the laundry room, and the laminate. I think the vinyl is on some particle board, or something else that’s sitting on the sub floor. I’m sure when I take up the laminate it’ll be easy to see.
    i haven’t been able to find any areas that I could look and see if there are two layers to the floor. I know the house was constructed in 1995, so I’m not sure if they were still doing that then.
    I appreciate the recommendations on the hammer drill and the chisel bits too. I’ll definitely use those.
    Thanks again!
    Dan
