There are some videos out there that give several methods you can use. Here is one that you can check out – https://www.youtube.com/watch?v=virO6RGakXU
Otherwise, using wood filler is a good option. You can also remove the trim, cut the nails holding the casing and reset the door. Sometimes that is the best option, especially when you have multiple doors.
