Activity Feed › Forums › Where should I start – Post drawings and questions › Starting in hallway almost perfect fit boards with doorjambs › Reply To: Starting in hallway almost perfect fit boards with doorjambs
Thank you so much! I appreciate your timeliness! I think with doing a seam in the middle of the doorways like you suggested, I can try to cut a U shape around the door jamb, so that almost an inch or so will be on the hallway side to cover up that seam as best I can. I have attached a few more pictures of that specific doorway and closet behind it of the other room.
