Activity Feed Forums Uploading Large Files Blue print Reply To: Blue print
  • Tracy
    June 26, 2023 at 3:44 pm
    Thank you! We are on a concrete slab. I was torn on which way to run the floor too. The small hallway between the two bedrooms is one area that would need to look even or it would show so I was thinking that’s the side I would start and that’s part of the reason I joined the bootcamp to see what you said. Around the bay window we did build a bench that runs straight across but I forgot to add that to the house plans. Besides making installing easier which direction do you think is more appealing. I probably would be happy either way. Thanks again for all your info. It makes this process a lot less intimidating.
