Activity Feed › Forums › Floor Prep › Laminate has foam › Reply To: Laminate has foam
I think you will be good to go. I would just be sure whatever else you are using is not foam and it is similar to the material that quiet walk is made of. You are not looking for cushion, you are looking for a solid feel to the floor that is sound deadening.
