Activity Feed › Forums › Where should I start – Post drawings and questions › Blueprint Request – nr › Reply To: Blueprint Request – nr
Hello, I am in the process of installing kitchen cabinets before starting the floor. I was thinking of putting 1/4in plywood under the cabinets to have them be closer to flush with where there is floor. Do you think this is worth doing? Also, would putting a thin plywood over an OSB subfloor give any advantage to the installation or integrity of the flooring, since it would be more uniform and smoother?
Thanks
