Activity Feed › Forums › General › Vinyl planks on stairs › Reply To: Vinyl planks on stairs
Thanks for the great reply as always. Would this Henry’s product be OK? I can get it right away at HD, and I can buy it by the quart. I’m thinking I’m only going to need one, maybe two quarts, and that would be $22, versus $40 for the gallon of the one you recommended.
I like the combo got glue/adhesive method you mentioned, although I’m likely to get about 8 hours before any traffic on the stairs if I do it right. What about putting hot glue inside the bullnose, instead of on the flat part of the tread? That way I could glue the whole tread, then use the bullnose to keep it in one place like you said. It also helps me use the extra box of glue sticks I bought and still have. 🙂
It would also be easy to leave the four corners of the tread area empty to use the hot glue there.
Thoughts?
