Activity Feed › Forums › Where should I start – Post drawings and questions › Blueprint/Floor plan request › Reply To: Blueprint/Floor plan request
Thanks! Makes sense.
Moving along…
I’m worried I’ve gotten myself in to a bad place. I somehow missed a significant dip in the family room (the starting room based on the layout plan you gave me).
You mentioned being able to use cardboard, but I assume that isn’t for large areas. As you can see, I am experimenting with adding some layers of underlayment. Not sure if this will work.
I’m getting the feeling I may need to pull this section up and properly flatten the dip.
It’s hard to tell exactly, but I’d estimate the area is about 6ftx3ft.
This reply was modified 11 months, 2 weeks ago by
Aron.
